| Home > Help Needed / General Tech Chat > Updated clutch | |||||||
118 Posts Member #: 9716 Advanced Member Edenbridge, Kent |
25th Aug, 2013 at 11:21:05am
Hi just spoken to someone who is building my engine and he says the standard metro turbo clutch is heavy and won't be up to the job for long and will burn out. So he said look for a updated ket with pressure plate thrust bearing the hole kit. Anyone know what one is good and anyone selling one please let me know ASAP thanks guys |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
25th Aug, 2013 at 01:10:58pm
what spec is your engine build? standard clutch with upgraded plate is ok for standard power, if your going for more theres the orange, gray and double gray diaphram plates or you could go rts Done now needs redoing lol |
25th Aug, 2013 at 01:20:47pm
Running about 100bhp what you think? Where can you buy kits from? |
25th Aug, 2013 at 02:30:22pm
the stock metro turbo clutch will work for 100 lbs/ft . a simple upgrade would be the stock clutch cover with a ap racing rally plate .that would be ample for your power and a fair bit more probably up to 150 lbs.ft.
25th Aug, 2013 at 02:36:52pm
Ok thanks il look into it |
25th Aug, 2013 at 02:44:10pm
I wouldnt run a preverto on a road car again,
25th Aug, 2013 at 02:48:17pm
Cheers joe just wanted to do it while it was out thought it might be worth it. |
25th Aug, 2013 at 05:38:24pm
http://www.med-engineering.co.uk/catalogue...-light-assembly |
25th Aug, 2013 at 05:38:47pm
Would anyone buy this? Or wasting my money |
25th Aug, 2013 at 05:41:10pm
Or looking at this
25th Aug, 2013 at 05:46:36pm
They are both pre verto. I'd be looking at verto clutches.
In the 13's at last!.. Just |
25th Aug, 2013 at 05:51:38pm
Sweet the mini sports ones ok? |
25th Aug, 2013 at 06:13:49pm
http://www.minispares.com/product/Classic/...ack%20to%20shop
25th Aug, 2013 at 06:54:08pm
Thanks that helps alot |
