Home > Help Needed / General Tech Chat > Head gasket for 998 turbo build.
smokestack-lightning.
Member #: 10557
Was just sat here with my little calculator (10kg pc) working out my possible CR ratio combinations pistons chamber etc...when a thought struck me.
The bk450 payen head gasket seems to be the best one for a turbo motor (excepting group A etc) But is there an equally good version of head gasket for the small bore turbo motor?
If an answer is glaring at me please someone point out my idiocy still a bit new to the turbo game.... *Confused*
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
A small bore gasket. Try a minispares copper.
Edited by gr4h4m on 26th Aug, 2013.
Member #: 10557
thats the jist what i was trying to get at. so there isn't a high quality compound gasket then? just the usual copper items? quite happy to use them it was just a case of: if there is a better alternative id use it that was all. thanks for the reply.
Mike-998
Member #: 9774
Buckinghamshire
Gavin (?) at minispares recommended this to me for my small bore turbo:
Though It didnt get many miles for the few days the engine had the turbo on, It looks a good bit of kit.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
thats the one i like monotouqe one i did use a silver ish one once it was SHIT i blew out cylinder to water jacket
I have tried it and it blew into the water jacket too.
Wilh uses the copper and gets good results
Mike-998
Member #: 9774
Buckinghamshire
That'll be the one to go for then
Member #: 10557
Cool thanks for the reply's people.
Just use the copper one as stated.
Unless you are fitting a large bore head, then use the BK450
Edited by wil_h on 1st Sep, 2013.
