| Home > Help Needed / General Tech Chat > pinking on a N/A engine | |||||||
225 Posts Member #: 3772 Senior Member Wigan |
26th Aug, 2013 at 08:27:37pm
hi all a freind has just phoned he has a 998cc N/A mini stage 1 kit fitted and he says its pinking at higher revs.
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
26th Aug, 2013 at 09:02:28pm
not sure if the hif38n has a tickler, best way to check timing is with a strobe gun with the vacuum disconnected. off my head i believe its about 8 degrees for a 998.
26th Aug, 2013 at 10:40:16pm
Cheers for that, got a timing gun but never used it. Any advice and where do I point it. Lol |
78 Posts Member #: 9073 Advanced Member Edinburgh |
27th Aug, 2013 at 12:21:38pm
There's an adjustment screw on the bottom back of the carb, about 10 oclock if you're looking from the front to adjust the jet up and down. It's recessed and you'll need a stubby screwdriver to get in to it.
Edited by Nial on 27th Aug, 2013. |
27th Aug, 2013 at 01:19:20pm
the old carbs used to have a blipper to richen out and help guide setup my question was if the hif has such a device. As regards needle i think it has had one done. |
27th Aug, 2013 at 01:31:10pm
27th Aug, 2013 at 02:12:06pm
It's just to set idle mixture assuming it's the correct needle. On 26th Jan, 2012 Tom Fenton said:
27th Aug, 2013 at 05:53:33pm
Yep, if its pinking at high revs then the lift pin (if it had one) wouldn't help. |
