Home > General Chat > I know we're always looking for a better underbody sealant....
I've just come across line-x. It's mainly a US company but they do have a dealer in the UK. It's mainly for truck bed and van liners, but they can do absolutely anything pretty much in almost any colour. It's basically a heated plastic sprayed onto the car in whatever thickness you want and dries in seconds. If you look on the linex uk site they've even done the complete body of a mini!
Now the end result is slightly textured, but it can be sanded flat and overpainted. I'm just thinking about this in the future of my build, it's practically bombproof stuff, completely waterproof and will basically seal the bodyshell in! Not sure on cost but they claim it's cheaper than a paintjob?
Actually,they have quite a few places across the uk!
my concerns with this sort of thing is can be brittle and chip/ crack, letting and holding water between the finish and the metalwork? all a bit like powdercoating?
I'd be a lot happier with a flexible sealant
Adam_R
Member #: 1938
near Dundee
http://www.linex.com/pages/2010/mythbusters_01.php
It's not like a hard plastic I don't think, it's a bit like rubbery plastic. So I assume its flexible.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i agree more flexible the better
smokestack-lightning.
Member #: 10557
Ithink this is the stuff they tested on mythbusters a couple of years ago.
sprayed one half of a car with the stuff
and crashed it a bit to compare results....then coated some wood with the stuff to see if it made a difference against C4....
http://www.youtube.com/watch?v=3JOXrpCLCJg
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
WRLondon
Member #: 8636
Surrey
looks good, i would personally want to replace all rusty panels, seal them and coat them with a zinc primer etc.
before but looks like a good idea
Cheers carl :)
Reading up on RTS Clutches
