| Home > General Chat > Boring and Reaming | |||||||
29th Aug, 2013 at 01:57:11pm
A couple of questions for you:
29th Aug, 2013 at 02:06:44pm
Being pedantic,Rob, but if you are boring a hole you can bore it to size. If, as I think you mean, you are drilling the hole then the allowance for reaming will depend at least partly on the material involved I,d say 0.1 mm is the most you would expect to ream out on most metals.
389 Posts Member #: 9751 Senior Member Derbyshire |
29th Aug, 2013 at 02:09:35pm
like my zeus book, this also has most of the engineering answers on fits, drilling etc
29th Aug, 2013 at 06:46:23pm
With regards to reaming, it all depends on what you are reaming, what finish you need and what the fit needs to be? I would always choose to bore an accurate hole before reaming it.
29th Aug, 2013 at 07:01:10pm
On 29th Aug, 2013 tadge44 said:
Being pedantic,Rob, but if you are boring a hole you can bore it to size. A competant machinist could, but I only have enough skill to make a mess so I figure it best to go with a low risk option, also as you say I'll be using a drill bit to make the original hole again as it's the hardest way for me to cock it up. Isambard Kingdom Brunel said:
30th Aug, 2013 at 06:53:31am
The good thing is your not talking about odd ball sizes. Best thing I can suggest is phone or go to your local Cromwell Tool store and ask them over the counter they will be able to sell you the correct drill and reamer combination you want, if your lucky they may have a drill reamer in the size you want or they can order it in and you will have it in a couple of days Own the day
30th Aug, 2013 at 07:46:41am
Exactly what are you trying to achieve anyway ? 9.85 @ 145mph
