Home > General Chat > Oil feed >.<
coopdog
Member #: 9628
I don't want to be a pain in the arse.....
Tried the search but I must be poo at it.
Looking for some info about a the oil feed for the turbo,
What does everyone else do??
Was thinking of putting in a t piece from the oil pressure sensor
http://minispares.com/product/Classic/Engi...k%20to%20search
Would this work?
minimongrel
Member #: 10419
http://minispares.com/product/Classic/Engi...turbo.aspx|Back to search
BAM! Follow the link
coopdog
Member #: 9628
Work with a 998 and t2 turbo?
I used -4 aeroquip type stuff from torques.co.uk
coopdog
Member #: 9628
Where did you take the feed from in the block?
smokestack-lightning.
Member #: 10557
I Believe most people do indeed take the feed from the oil pressure sender point and T in the oil pressure sensor to the side.
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
coopdog
Member #: 9628
yes as above because the oil is filter from the main oil gallery.
WRLondon
Member #: 8636
Surrey
yep i've got it tee'd in from the pressure gauge :)
Reading up on RTS Clutches
