Home > Beginners Tech > Standard cr rate in a 10grb ta h?
Flodin
Member #: 10556
Hallstahammar, Sweden
Is it correct that i have a cr aroud 8.5 in my 10grb ta h? I think i read this some where.
Thanx in advance!
What's a 10grb? Don't think anything A series had a CR that low from the factory.
Looks like an MG1100 engine number so probably 8.9:1 was the intended CR from factory.
welshdan
Member #: 1111
s wales
didn't some vans have really low compression ratios?
Lots of pre a+ engines were 8:1 too.
Remember that many of the factory low cr pistons were low quality to match the low stress nature of the intended application.
and the wank fuel at the time dave
2* star you wont remember gents you weren't born
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
crap fuel thats still present..
some days ill fill up the work ute and it detonates like made others its fine on the same hills/roads
pain in the ass i move the timing accordingly although ist quite noticeable when restarted hence trying to keep it on the sweet spot..
Flodin
Member #: 10556
Thanx
I read somewhere that it has 8,5:1 but when i calculate i get 9,6:1 and that sounds more accurate because it`s a "ta h" = high comp engine. But i will calculate again when i have pulled a part everything and measured.
tadge44
Member #: 2500
Buckinghamshire
Too young to remember Steve ? I remember fuel without any stars !
You had a choice between "Commercial" or "Premium". Later came Super Premium or, as it came to be known, 5 star.
