Home > Introduce Yourself > New Boy with turbo mini
Andys101
Member #: 611
canterbury
just bought a '72 mini fitted with a mg turbo
the engine is sick (smokes bad) and im going to carry out a full restoration.
I would like some surgestions on what mods i can to to the engine :cool:
Kean
Member #: 341
aka T2clubby
South Staffs
Welcome to the forum mate, ur smokeness could either be worn rings or a goosed turbo..
if you are lookin at rebuilding, bore it out to 1293 and drop a decent set of pistons in ...
It all depends what you want to spend and how much power you want.
Use the search button at the top to find all the info you need, there is tonnes on here about pretty much everything you need to know
Welcome.
There is a million and one different posts about this, you've found the right place for information.
Nicky
Member #: 333
Tadley, Hampshire
Hi, welcome :)
Andys101
Member #: 611
canterbury
Thanks i have been looking around and you are right there is so much info on this site... its great
what i would like is about 130 bhp ish and drivable on normal roads but enough to pi$$ off the normal gti boy racers (and the wife would like to do the same)
what i have gleaned from looking around is the following - please correct me if i am wrong
rebuild box properly
straight cut drop gears
twin pin diff
duplex timing gears
mild cam
1293 bore with good pistons (no idea which please help)
stage 2 head (again no idea which one)
intercooler
9psi actuator
moded carb (i think it already has this i will need to check)
bleed valve (to lower boost for normal driving)
i already have a super 2 core rad and a 13 cor oil cooler but i have read that the oil cooler needs a thermostat
any help is much apreciated
to see what i have done in the past have a look at my web site
and follow the links
www.craftsmanhooper.plus.com/andys101.html
Hi and welcome
