Home > General Chat > 998 tech
dev 11
Member #: 9393
stoke on trent
Alright folks ive been given a 998 full engine, the bloke said it smoked slightly when it got warm, so he changed the valve stem seals but no avail and ripped it out, so im thinking about putting a mini together out of spare parts using this engine
What you reckon strip maybe a re ring will obviously check bores but im also going to pocket block and run 12g940 head on it.
Where would you draw the line as I want to budget my build. ..
Start with a compression test. That will give you an idea where the problem is.
smokestack-lightning.
Member #: 10557
Are you planning to turbo it then?
Edited by smokestack-lightning. on 2nd Sep, 2013.
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
Member #: 10557
god---please delete this:$
Member #: 10557
Member #: 10557
Member #: 10557
I don't think god is listening to you.
supermotolee
Member #: 2153
kings langley
DOH!!!
Member #: 10557
...just not my day...
dev 11
Member #: 9393
stoke on trent
Is it possible comp test with engine on bench?? Never done it that way.. could always rig starter up
Haha no the turbos going in my 1360 van, just want a mini on the road and have a good shell and enough spare parts build one in my spare time. Tempted 998 12g940 head then maybe weber
Only needs power and earth to do it.
wng691s clubby
Member #: 9252
Cleethorpes
if comps good itl be guides
Done now needs redoing lol
WRLondon
Member #: 8636
Surrey
5 posts wow lol
Reading up on RTS Clutches
