| Home > Help Needed / General Tech Chat > AFR / RPM graph | |||||||
69 Posts Member #: 10545 Advanced Member MAURITIUS |
2nd Sep, 2013 at 12:24:36pm
2nd Sep, 2013 at 01:27:24pm
i would have thought load not rpm would have a bigger bearing on the numbers |
2nd Sep, 2013 at 03:42:12pm
I understand,
2nd Sep, 2013 at 03:50:22pm
it sounds like you dont know what your doing so the only advise i could give is find some one who does Yes i moved to the darkside |
2nd Sep, 2013 at 05:33:10pm
Your probably right, I'm totally new in the subject but I like to learn and find informations.
93 Posts Member #: 9597 Advanced Member |
2nd Sep, 2013 at 05:58:20pm
I have an AEM gauge that logs boost, afr and rpm. It comes with a usb cable so that you can download the logs and check out all your data. It does everything you seem to want, all you need it someone who knows what all this stuff means to help you understand it and figure out what to do with the data.
2nd Sep, 2013 at 06:17:16pm
Thanks for your answer,
2nd Sep, 2013 at 08:19:24pm
I run about 14-15 on normal driving, it goes up to 16 off boost on a steep incline.
2nd Sep, 2013 at 09:25:55pm
Idle you should aim for 14.7:1
3rd Sep, 2013 at 04:07:39am
This are the informations I was looking for.
3rd Sep, 2013 at 08:43:40am
helpful info Sprocket cheers
19th Sep, 2013 at 02:00:42pm
Finally installed the gauge/sensor
78 Posts Member #: 9073 Advanced Member Edinburgh |
19th Sep, 2013 at 05:16:19pm
Try thicker oil in the dashpot.
19th Sep, 2013 at 05:43:50pm
Thanks for your reply, I was using automatic transmission oil then have changed for 20w50 and used a stronger spring, should I try an even thicker oil like manual gearbox oil ?
224 Posts Member #: 9987 Senior Member Amsterdam |
19th Sep, 2013 at 06:00:14pm
Just buy a few spare needles similar to the one you have now and file them in the lower 3rd region to richen things up....
19th Sep, 2013 at 06:25:46pm
Yes will try the filing, looks so interesting !
19th Sep, 2013 at 11:16:21pm
Great post Colin, what about overrun esp on FI cars
On 2nd Sep, 2013 Sprocket said:
Idle you should aim for 14.7:1 part throttle/ cruise aim for 14.7:1 to 16:1 full throttle for Normally Aspirated engine aim for 12.6:1 and no richer Full throttle for forced induction same as normally aspirated but depending on boost level you can go richer still but there is no real need to go lower than 12:1 and anything beyond 11.5:1 is un necessary unless you realy are pushing the boundaries of mega boost levels. Thise are general rules on steady load conditions, expect rich and lean spikes as the throttle position is changed, as that causes the volume of air to change one way or the other making the carburetter react accordingly. Under quick throttle chang conditions you will see this the most. As for RPM, generally anything lower than 4000rpm and less than 50% throttle should be considered cruise and a near stoichiometric fuel ratio (14.7:1). Above 4000rpm and less than 50% throttle, start to richen things up a little, say 14:1. above 50% throttle start to richen up towards the 12.5:1 at full throttle. I say this as if it were fuel injection where you can easilly achieve these figures in specific areas of throttle and rpm, but with a carb, you might only be able to achieve the cruise 'lean' areas and the full throttle areas, everywhere else might be a compromise. Remember that momentary rich and lean spikes are OK so long as they do not cause any adverse results, rapid throttle position changes will create these tyoes of conditions so when trying to tune anything regarding fueling, avoid that type of throttle condition. Hope that helps. I run a supercharger and I don't care the TB is on the wrong side.
20th Sep, 2013 at 07:50:53am
Overrun on an FI engine should see at least 20% oxygen above 2500rpm (fuel cut) and aim for 14.7 bellow that. Remember though that the transition period from fuel cut can cause massive lean then massive rich spikes, and takes a little time to tune out when using closed loop fuel control. The thing to do there is apply a delay on the closed loop control after the fuel has first been re applied. It's all about the datalogging On 26th Oct, 2004 TurboDave16v said:
20th Sep, 2013 at 11:44:14am
On 19th Sep, 2013 minimauritius said:
Thanks for your reply, I was using automatic transmission oil then have changed for 20w50 and used a stronger spring, should I try an even thicker oil like manual gearbox oil ? But even if I keep it wide open It doesn't richen more so was thinking the only solution is changing/ modifying the needle. Is 13.5 AFR on WOT dangerous ? The oil viscosity is what control how much richer it gets when you put your foot down, it won't affect static conditions. A stronger spring will stop the piston rising as far for each steady state condition, ie at a given steady engine speed the piston will be slightly lower with the stonger spring. If the piston's lower a wider bit of the needle will be controlling the fuelling so it'll run a bit leaner. You could experimentally cut coils off the spring to make it slightly weaker to see what happens? Nial |
20th Sep, 2013 at 10:48:46pm
A stronger spring has the effect of a richer mixture. I run a supercharger and I don't care the TB is on the wrong side.
