| Home > General Chat > over size Cam Followers ? | |||||||
5th Sep, 2013 at 11:13:15am
just a thought that i may need some i asked the shop to check the bores and new lifters for the build hoping its all good if not where could i find some over size Cam Followers? |
109 Posts Member #: 10368 Advanced Member Australia |
5th Sep, 2013 at 11:49:53am
pm sent |
224 Posts Member #: 9987 Senior Member Amsterdam |
5th Sep, 2013 at 06:03:04pm
The monte carlo works minis used to run larger diameter MGB followers.... |
174 Posts Member #: 9128 Advanced Member |
5th Sep, 2013 at 07:11:09pm
On 5th Sep, 2013 Evoderby said:
The monte carlo works minis used to run larger diameter MGB followers.... Gives you a little more duration and initial lift....... Edited by DILLIGAF on 5th Sep, 2013. |
5th Sep, 2013 at 09:25:30pm
Dilligaf, how so? probably a dumb question sorry
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
5th Sep, 2013 at 09:41:56pm
no it doesn't ,
The monte carlo works minis used to run larger diameter MGB followers.... Gives you a little more duration and initial lift....... |
5th Sep, 2013 at 10:00:14pm
yep, as carl says,
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
5th Sep, 2013 at 10:50:47pm
lifter bores are usually ok i think. you can have larger followers installed if you want to run very aggressive cam profiles as the diameter is the limiting step for the amount of acceleration you can get away with. Calver has a few race cams that use them That sir, is not rust, it is the progressive mass reduction system
5th Sep, 2013 at 11:09:49pm
with the more aggressive ramp (Sir Yun and Joe) is it the bigger diameter against the follower bore that helps the follower 'slip' vertically rather than horizontally ( ie not get jammed) or something else. excuse poor explanation - |
5th Sep, 2013 at 11:37:59pm
Surely if the follower is wider, the cam will start to lift it earlier ? |
6th Sep, 2013 at 12:46:04am
like i say at this stage this post is a just in case i need some over sized ones the shop is going to check them out and let me know im just trying to be one step ahead so im not told hey you need some over sized followers and be all shit where the hell do i find those.. id rather it be a matter of no prob and just order them in.
6th Sep, 2013 at 06:14:03am
the need for a wide follower is to stop the nose of the cam falling off the edge ,
6th Sep, 2013 at 06:47:51am
thanks fast carl |
