Home > Help Needed / General Tech Chat > Shultz or not...
evad1980
Member #: 10165
Stansted, Essex
Ok so almost ready to stone chip the underneath of the estate... Before I go out and buy the wrong thing let me pick your brains please..
Halfords sell a hammerite stone chip sprayed straight from the can, or on eBay I can get various other brands that require a Shultz gun... What's the difference?
Any benefits from using the Shultz gun or will the can be ok?
the Shultz gun as you can leather it on to your required depth, with a spray can you will use dozens to achieve the same result at more expense!
Shultz guns are cheap check them out on ebay
evad1980
Member #: 10165
Stansted, Essex
Ok Steve great... eBay here I come....
get the gun, its messy but good stuff
But are you covering it in Shultz or stonechip to then paint over !!!
Rick
evad1980
Member #: 10165
Stansted, Essex
Rick
Well what I have done is protect all the underside with a hammerite anti-rust paint, brushed on a few coats and the plan was to spray a stone chip over that. The stone chip would be the final layer, sprayed on with the Schultz gun.
As far as I'm aware, stone chip need not be painted over? It can be the final layer?
jonny f
Member #: 9894
Dorking
Heard excellent things about this stuff.
http://www.ebay.co.uk/sch/i.html?_odkw=sto...avitex&_sacat=0
Edit...
UPOL gravitex.
Edited by jonny f on 8th Sep, 2013.
evad1980
Member #: 10165
Stansted, Essex
Ya was looking at that stuff.. Looks good gear..
Chalkie
Member #: 9764
Northamptonshire.
Halfords sell Shultz guns down the paint section of the store
If you have already painted the underbody I would apply underbody wax. Stone chip should be applied to bare metal or a primed surface then painted over with the top coat.
I'd suggest you look at an underbody wax (not the Waxoyl shit) I recommend the Dinitrol range of products. They recomend you apply a thin layer of cavity wax first then the underbody wax. wax is the logical thing to apply on the underbody, you apply it to the rest of the car, why not the underbody?
Have a look here http://www.rust.co.uk
evad1980
Member #: 10165
Stansted, Essex
Ooooop's.. Just ordered some stuff off eBay... Too late! Oh well, we'll give it a go!
I'll give the verdict on my build thread when it arrives!
Sorry I haven't replied sooner, im sure stonechip is pours like primer so needs to be overcoated with something.
Sounds like you already have something but have a look at u pol raptor !!
rick
evad1980
Member #: 10165
Stansted, Essex
Ok I'll investigate that, cheers...
Seen that raptor stuff, people were using it on the flat beds of pick up trucks.
Anyone else know if the stone chip can be the final layer?
I'd take Rick's word on it considering autobody and paint are pretty much his profession.
evad1980
Member #: 10165
Stansted, Essex
Ok guys, may have to rethink this one..
Cheers..
Right update
I was wrong!!
It isn't pours and it can be used as a final finish underneath.
It wont stay spotlessly clean so wouldn't be great for a concourse build as it does stay rubbery so obviously ideal for underneath as its designed for.
rick
evad1980
Member #: 10165
Stansted, Essex
Thanks Rick for investigating that... Nice one!
