| Home > Help Needed / General Tech Chat > R5GTT intercooler modification | |||||||
18th Jul, 2005 at 11:56:44am
Pretty sure I read somewhere that they have a inbuilt thermostat,that needs by passing/blocking ??
18th Jul, 2005 at 04:15:52pm
prise back the fin flange thingys holding the end cap on and take it out...makes them flow better!
Yes you are right, they have a thermostate that allows the air to flow straight in and out the end cap of the intercooler, and closes when the air gets to a certain temperature so it will then pass through the core. I brought my R5 intercooler with this mod allready carried out but its simply a job of bending the alloy tabs so the end cap can be removed, remove the thermostate and fit a blanking plate in. Mine has been riveted in place, they apparantly flow better once this mod has been done! Also a good idea to strap the intercooler as they are know to blow apart, especially as bending the retaining tabs will weaken them a tad. A huge jubillee clip or similar will help to hold it in one piece. -MINI CLUBMAN 1380 TURBO- |
18th Jul, 2005 at 04:17:10pm
Kin ell T3toad you must have pressed enter a nanno second after me!!!!! On 21st Jan, 2011 fastcarl said:
18th Jul, 2005 at 04:20:41pm
T3 toad!!!!!!lol
27th Sep, 2005 at 01:56:06pm
Next prob,it is too tall.Mk 1 metty has a higher slam panel than a mk 2 metty
27th Sep, 2005 at 02:09:42pm
strap the IC as well if your going for high pressure!
AlexF |
27th Sep, 2005 at 02:55:03pm
For sure - don't just take it out mind, or air will take the easy route and just by-pass the core!
used the search button but cant find it now
