Home > Help Needed / General Tech Chat > No boost
Jim974
Member #: 10517
Hi everybody,
I just finished to build my mini turbo with a metro turbo engine.
I did my first tests today.
My car starts but when I accelerate I do not feel the turbo. I have no boost and the needle of the manometer turbo do not move.
My first idea my turbo is dead but that is strange it is I hear the turbo to whistle, thus I suppose that it is well-funtionning.
Anybody would have an idea?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Are you driving the car or just reving it on the driveway. If it is the latter you will not make any boost.
Take off a pipe from the compressor and give it a good rev and put your hand over the pipe. You should be able to feel the air being pumped, just not enough to register on a gauge.
http://www.twin-turbo.co.uk
Jim974
Member #: 10517
Hi Ben,
At the beginning of my tests I accelerated, gear in neutral position, while in my garage to rev it.
Given that I heard the compressor whistle but no movement in the manometer I tested it on the road and really reved it, but no boost …
When you say:” take off a pipe from the compressor”, you mean the pipe which connects the actuator?
No. The one which feeds the carb.
Jim974
Member #: 10517
I think it’s blows in this place because I have a dump valve between the pipe of the compressor and the plenum and we hear the “pchiiiit”.
I shall all the same test to remove the pipe to see.
If the air being pumped, is it normal I don’t have boost?
Thank you for advices
Where's the gauge plumbed in to?
redrat
Member #: 9107
Devon
A picture / diagram of your set up would help I think .
Jim974
Member #: 10517
It is connected between the compressor and the actuator (just after the pressure boost controller)
I will post a picture as soon as possible
Jim974
Member #: 10517
this is a picture:
http://imageshack.us/photo/my-images/706/f4zp.jpg/
Ben H
Member #: 184
Move the gauge. It should be on the inlet manifold, i.e. after the butterfly.
that said you should see something on the gauge where you have it now, if you are making boost that is. Would be an odd signal though.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Looking at the pic, if you had the boost controller fully closed the gauge would register no boost. Best bet is to plumb the gauge into a take off on the inlet manifold.
On a side note, I had a similar problem where the actuator arm had come off the waste gate flap, turbo would whine but no boost as the waste gate was fully open all the time.
"Try to take over the world!"
Jim974
Member #: 10517
thnak's for yours advices...is it possible to have a picture of your assembly?*happy*
I changed my actuator a few days ago. And I don't know if the distance of the actuator arms is good.
How can I to know the good distance?
You need to preload the actuator by making it shorter. Align the arm so that it is shorter by around half the width of the hole in the arm.
So you'll need to pull the arm over the pin on the actuator flap.
Ben H
Member #: 184
This is a useful thread:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=257121
Jim974
Member #: 10517
Thank's guys..... *hehe!*
you are the best!!
