| Home > General Chat > OT: VW Golf TDI query | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
11th Sep, 2013 at 11:16:37am
Was wondering if there is some knowledge about VAG diesels..?
Dazed and Confused.... |
11th Sep, 2013 at 12:13:41pm
Gear box is on its way out sorry to say.
11th Sep, 2013 at 12:38:53pm
For the warm start issue it sounds like one of the engine sensors is not working well, possibly the coolant temp sensor. I would get a diagnostics box plugged in. On 11th Feb, 2015 robert said:
11th Sep, 2013 at 01:50:48pm
Thanks for your reactions...
11th Sep, 2013 at 02:39:25pm
My mate had a 2006 and his DMF failed and took the gearbox with it. http://www.twin-turbo.co.uk
1170 Posts Member #: 8636 Post Whore Surrey |
11th Sep, 2013 at 03:12:56pm
Problem with vags post 2003
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
11th Sep, 2013 at 04:30:32pm
On 11th Sep, 2013 WRLondon said:
Problem with vags post 2003 The pd engines are bullet proof the rest arent built to last, as if you keep your vag for 10 years plus you won't buy a new one! Is anything built to last these days? Surely its pretty much throw away after 10 years with everything modern. On 7th Oct, 2010 5haneJ said:
11th Sep, 2013 at 04:32:19pm
On 11th Sep, 2013 Yo-Han said:
Are 6 speeds better? Would it be possible to fit a 6 speed when this box gives up completely? I believe the 5 and 6 speed boxes are interchangeable. On 11th Feb, 2015 robert said:
11th Sep, 2013 at 09:13:30pm
Problem with vags post 2003 The pd engines are bullet proof the rest arent built to last, as if you keep your vag for 10 years plus you won't buy a new one! Is anything built to last these days? Surely its pretty much throw away after 10 years with everything modern. Unfortunately very true, it one of the continuing discussions at work lately. You are 'forced' to put cheap sh!t in appliances to be able to compete with the market. Problem is that applainces should remain safe untill people stop using it, also in extreme cases... some companies take shortcuts that create untollerable (sp?) risks, just to make mony.. unacceptable in my eyes! (and fortunately also to company I work for) On 11th Sep, 2013 apbellamy said:
Are 6 speeds better? Would it be possible to fit a 6 speed when this box gives up completely? I believe the 5 and 6 speed boxes are interchangeable. That makes things a bit interesting, I do quite a few motorway kms so would help economy. But are these 6speed boxes any stronger? Dazed and Confused.... |
261 Posts Member #: 713 Senior Member Western Australia |
12th Sep, 2013 at 01:41:37am
Strong enough, but there was a known issue with the diff bolts from memory. Ours spat something right out the side of the gearbox casing but still worked fine. Poor mini got the blame for the leaking oil at first. New gearbox under warranty. On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
12th Sep, 2013 at 07:03:13am
My tdi 130 with 6 speed box is on about 190k miles and still fine. On 11th Feb, 2015 robert said:
12th Sep, 2013 at 08:26:32am
Thanks for that chaps!
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
12th Sep, 2013 at 06:53:31pm
On 12th Sep, 2013 apbellamy said:
My tdi 130 with 6 speed box is on about 190k miles and still fine. Andy done 120K in my pd130 with 6 speed and its still sweet as a nut. Give the guys at Darkside developments in Yorkshire a call for advice and go faster parts they are really helpful. Jawd |
