| Home > Help Needed / General Tech Chat > abit of help on the plenum? | |||||||
57 Posts Member #: 9625 Advanced Member |
12th Sep, 2013 at 05:56:24am
hey guys , i was wondering what the spring is for under the intake for the plenum ? also can a new pipe be made up for the plenum to replace the existing rather than having 2 pieces welded together i was thinking of making a flange with quite a long pipe on it to wrap around the dash pot and head over to the clutch side of the engine bay
12th Sep, 2013 at 07:03:37am
The only spring in the plenum is the over boost valve. Most people just block it off.
Edited by Ben H on 12th Sep, 2013. http://www.twin-turbo.co.uk
12th Sep, 2013 at 07:22:37am
Yes. You can make a replacement for the 'gonzo nose' piece. You could also make the flange large enough to cover the overboost valve. In the 13's at last!.. Just |
12th Sep, 2013 at 09:17:00am
aahh sorry about the explanation XD ,cheers for the reply guys |
12th Sep, 2013 at 09:43:30am
also doing a custom 'gonzo nose' piece
