Home > Help Needed / General Tech Chat > Should I be concerned?
dion
Member #: 9169
Cape Town, South Africa
After stripping my engine to sort out an oil leak I thought I might as well remove the cylinder head just to check for signs of detonation. I've become paranoid about detonation after reading so much about it on here*surprised* . I'm running half bar boost, 9.0 cr, 97 octane, omega 11cc pistons and about 18 degrees advance. To me it just looks like no4 piston has run hotter than the rest. I do plan on upgrading the radiator as it did get hot about 100 degree C.
Any thoughts?
Was there any problems with the gasket? Possibly leaking anywhere?
tadge44
Member #: 2500
Buckinghamshire
What are the marks on two and three that look like pock marks ?
Given your boost and timing, unless it was running very lean I would not have expected any detonation, though.
dion
Member #: 9169
Head gasket was ok, I've got a cometic gasket that I'm in two minds about using, if I use it I will get my cr a little lower.
The marks in the center of the piston are little raised pieces that I assume were left over from the machining process.
I think the darker colour of no4 piston is cos its got hot, I'm going to add a small radiator onto the head bypass, hopefully this helps.
