Home > Help Needed / General Tech Chat > should i or shouldn't i??
turbochargedstu
Member #: 908
gateshead
Should i or shouldnt i????????
it does already have a nice spec benross 12g295 head, and the clutch needs doing soon. plus the engine itself needs a rebuild.......*oh well*
balls to the blower!!!
yes
evad1980
Member #: 10165
Stansted, Essex
Certainly!!
These look the dogs danglies with a set of 5.5" minilites. I'd have to lose the headlamp 'brows and the (real) wing mirrors however.
Yes
Yes but get rid of those bloody headlight peaks though
I once co owned a Wolseley hornet, it was ace, would have loved to have finished it!
turbochargedstu
Member #: 908
gateshead
would a turbo motor work on a magic wand box? or would the timing of the change be too slow and not worth it?
as the guys says .. above but I would love to add an insane turbo engine, and leave it as a sleeper car to fook all the chavs of, dump the magic wand box and fit a remote set up with sc clubman set etc .....
you just need the flat hat which john and Andy bellamy can provide two types*happy* and the pipe I can provide also .... *happy* *laughing*
turbochargedstu
Member #: 908
gateshead
im thinking of just a mild 998 turbo set up, but trying to keep it standard looking. i have the sprite to fuck the chavs off with when i get it sorted eventually.
dont fancy chopping the floor out steve hence the magic wand.
yeah lose the peaks, keep the majic wand, do a decent boost level on the 998, drop an inter cooler behind the elf grill!
you have a point joe,
stu if you are going to spend money you may as well spend it on the bigger cc engine for the same cash IMO theres no substitute for cc .....plus + boost
