| Home > Introduce Yourself > cant get clutch out of my mini 1380 turbo any help would be grate | |||||||
6 Posts Member #: 10597 Junior Member from london now live in essex |
15th Sep, 2013 at 09:13:22pm
hi my name is steve I cant get my clutch out of my 1380 turbo and I think it is ceased on there so any help would be grate it doing my bloody head in thanks |
134 Posts Member #: 9579 Advanced Member Tadley, North Hampshire |
15th Sep, 2013 at 09:28:02pm
Don't skimp on tools and get a minispares puller. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
15th Sep, 2013 at 10:49:06pm
Hi we need more info off you please tell us exactly. Whats problem. ?
28 Posts Member #: 9094 Member near hull |
16th Sep, 2013 at 05:37:18am
i struggled getting the clutch off on mine, i ended up having to use a combo of a puller and blow torch to warm it up but it was a lot easier as i had the engine out the car |
16th Sep, 2013 at 07:44:19am
Welcome to TM Steve
16th Sep, 2013 at 09:09:44am
Many people forget the key washer, also I use old main bearings for locking the flywheel, works a treat. On 26th Jan, 2012 Tom Fenton said:
16th Sep, 2013 at 09:34:37am
On 16th Sep, 2013 Carlzilla said:
Many people forget the key washer, also I use old main bearings for locking the flywheel, works a treat. that's my bit of knowledge for the day ill have to try remember that |
16th Sep, 2013 at 10:28:09am
A long breaker bar, if needs be leave the puller on over night and you may find by morning it has eased. Own the day
![]() 178 Posts Member #: 10196 Advanced Member |
16th Sep, 2013 at 12:29:53pm
On 16th Sep, 2013 Mr Joshua said:
A long breaker bar, if needs be leave the puller on over night and you may find by morning it has eased. That method works, had one ultra stubborn one so left it overnight, then used a little heat and it popped off |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
16th Sep, 2013 at 12:31:04pm
4 weetabix What the mind can conceive the mini can achieve
78 Posts Member #: 9073 Advanced Member Edinburgh |
16th Sep, 2013 at 12:37:13pm
I thought the accepted technique was to wind the puller up as tight as you dare then hit the thing hard with a BFO hammer?
17th Sep, 2013 at 08:18:24pm
thanks everyone I got a puller from a friend I now have removed the clutch I will post some pic of my progress once I have work out how to put them on LOl |
17th Sep, 2013 at 09:46:06pm
what i tend to do is tighten the centre bolt on the puller to within an inch of its life then gently warm it with a blow torch between the puller and flywheel and it pops off on one occasion it took half the crank with it but that had spun already Yes i moved to the darkside |
18th Sep, 2013 at 12:17:19am
hello I have got my engine apart now and I now have found that the gearbox has got something wrong with it one of the bearings have broke it is on the left hand side of the box where the speedo connects to the main shaft I think the thing is it all still works on closer inspection it look like the plastic has broke that holds the ball bearings in place can anyone tell me is it a easy fix and where to get one form thanks |
![]() 270 Posts Member #: 69 Senior Member Coventry |
18th Sep, 2013 at 08:50:57pm
where in country are you?? |
