| Home > General Chat > Cylender head valves for high boost use on small bore? | |||||||
17th Sep, 2013 at 09:08:27am
as above can anyone recommend what valves are good for 20-30 psi boost on a small bore head (202)
Edited by Turbo This.. on 17th Sep, 2013. |
17th Sep, 2013 at 06:29:46pm
If you're planning on running that kind of boost I wouldn't be using those two pice valves, otherwise you could see the head departing from the stem. You want a stainless one piece valve. Though you're a bit limited on size, Minispares sell a larger inlet:
Edited by Turbo Phil on 17th Sep, 2013. |
