| Home > Help Needed / General Tech Chat > what can a stadard engine take ? | |||||||
57 Posts Member #: 9625 Advanced Member |
20th Sep, 2013 at 07:04:28am
hey guys , im looking at buying a complete metro turbo setup if tis at the right prce , now i was wondering what sort of power can be run through a standard 1275 engine or even a thou with the cr lowered ? at the mini i own a mini and a metro and pinched the metro engine and built a fast road 1275 for the mini , and stuck the tired 998 in the metro as a daily xD(it would stay a daily with a turbo on so wouldnt be looking to run loads through it) , now this setup comes with the metro exhaust so i thought if i get it ,it would be rude not to turbo the metro while i build an turbo engine for the mini but i dont fancy strapping it all to the engine thats in, i would prefer buy a half decent engine and chuck that in , it comes with a t3 that is to big for a thou isnt it ? so would a gt17 be a better alternative and does it fit on standard manifolds ? or would i be better trying to get a 1275 and run the t3 on it ?
20th Sep, 2013 at 07:13:34am
Read this:
http://www.twin-turbo.co.uk
20th Sep, 2013 at 08:45:10am
i had a read through that at first , but it doesnt really say anything about the power its making after wards also anything about the gt17 on a standard manifold |
20th Sep, 2013 at 09:38:24am
It made a smidge under between 80 and 100bananas.
20th Sep, 2013 at 09:43:36am
Have a search for the thread on out metro van. Standard turbo pistons, totalseal rings, phase 2 cam and a very well ported big valve head gave over 200 bananas with a gt17 turbo. It just fitted in the metro engine bay with the turbo notched to fit the standard t3 manifold. If I was doing it again I would have notched the subframe as everything was very very tight down the back. On 11th Feb, 2015 robert said:
20th Sep, 2013 at 09:45:57am
ahh so the gt17 is better suited to a standard 1275 ? it does come with a t3 but ive been lead to believe that its old tech now and doesnt come on boost until higher up in the rev range ? or will the t3 be alright as a aily drive on a 1275 ?
20th Sep, 2013 at 11:04:08am
On 20th Sep, 2013 apbellamy said:
Have a search for the thread on out metro van. Standard turbo pistons, totalseal rings, phase 2 cam and a very well ported big valve head gave over 200 bananas with a gt17 turbo. It just fitted in the metro engine bay with the turbo notched to fit the standard t3 manifold. If I was doing it again I would have notched the subframe as everything was very very tight down the back. is this the thread you were on about ? http://www.turbominis.co.uk/forums/index.php?p=vt&tid=286312 |
20th Sep, 2013 at 11:21:18am
Yes the GT17 is great on a 1275. They work well on the 998 in a race application, but on the road it would be tedious after the initial grinning.
On 20th Sep, 2013 oliver122 said:
ahh so the gt17 is better suited to a standard 1275 ? it does come with a t3 but ive been lead to believe that its old tech now and doesnt come on boost until higher up in the rev range ? or will the t3 be alright as a aily drive on a 1275 ? cheers for the replys Ben http://www.twin-turbo.co.uk
20th Sep, 2013 at 11:31:39am
Nope, this one.
20th Sep, 2013 at 11:44:21am
I slagged the T3 off for years as a shit old lump. But that was after my experience of it on a 998. Now I have driven a 1275 with a T3 it's not as bad as I thought it might be.
20th Sep, 2013 at 12:01:04pm
When the van had a t3 and a n/a mg metro cam it was a nice fast drive on about 12psi. We ruined it by fucking about with other turbos and cams, light weight stuff etc. If we had left well enough alone, chances are we would still have it... On 11th Feb, 2015 robert said:
20th Sep, 2013 at 01:58:07pm
the t3 is an ancient unit but it still works! I have run different spec t3s on both of my turbo engines, and they have been very drivable and made very good power for the boost.
