Home > Help Needed / General Tech Chat > suspension settings?
Carl
Member #: 95
liverpool-on-sea
after avon me 1st priority is sort me car out suspension wise.
so can any1 give any advise to settings
im assuming front camber 1.5 degrees. toe 0 or a little to in?
what about rear camber and toe? what about caster, same as standard?
any hel[ much apprieciated thanks*smiley*
p.s tyre wear unimport handling main priority*tongue*
these are my settings but each to there own..
1.25 neg front camber caster set to 5.5 deg which is just about right and helps torque steer and vastley improves the handling
i did run the caster at 9 deg at one time but
found this a tad too ..! demanding
the rear i have set to 0 camber standard and left it at that!
it handles FANTASTIC! and is a pleasure to drive
Volodkovich
Member #: 626
Wellington, NZ
benross, when you had the castor set to 9degrees did it actually help the handling, despite being a handful? (i expect heavier steering?)
hi carl
set at 9 degrees it helped torque steer some what
at the expence of the wheel been hardis ish.. to turn going into the corners
coming out of the bends it was not to my liking as there was a little too.. much self straightning
i have found 5 deg is about right
i personally would not go over this
but sure give it a go
GOOD LUCK!
Hedgemonkey
Member #: 360
Front camber -2deg, rear -0.75deg rear tow in, just a micron above dead ahead, 14mm anti roll bar (rear), about 1/2 the factory front tow out (can't remember offhand), 7deg castor.
Longman used to run positive camber rear to de-grip the back, pretty much the same as a rear anti roll bar. Recently, I've been thinking about running harder compound rear tyres to let the back drift a weeny bit. Currently on 032's. Might put 008's on the back. My setup was based around this, I bought the rear roll bar to enable me to run it lower than normal without binding the arches up, this had the effect of making the car understeer less, had a tendency on crap tyres to slide, was running quite a bit of rear tow in, noticed how important 3 wheel steer was with RAB and got it pretty much dead ahead, when you chuck it into a corner, it doesn't snap (too much tow out) or weave (too much tow in), the rear sticky tyres and -ve camber keep it from sliding and it's great. I cannot speak highly enough of rear ARB's, they made the thing corner properly. What I did with the shocks was weighed the front axle and the rear and set the shocks dead hard and the back at the same ratio backed off. I can't remember my figures but I used the same thing for rear camber. I reckon it's a good starting point.
Came across the other day, thought id add it in the mixing pot *happy*
Courtesy of the mini 7 website
going a bit off topic, what tyre pressures do you guys use for 10" 32r's
Carl
Member #: 95
liverpool-on-sea
cheers iain, i had a go last sat got everthing straightish, i just need some new arches and road tax and i can try it, and take it from there.*smiley*
i checked my settings last week-
front +0.5deg positive camber, no toe in running dead straight
rear -2.5neg camber a bit of toe out, uneven spax settings
perhaps that was the cause of my crap handling around the twisty bits at the back
im running 29psi front and 26psi rear on my tyres
Mirage
Member #: 119
Suspension settings for dragging or for road use. These would be quite different.
mirage, can you go into a little more depth?
bawbee
Member #: 191
Falkirk, Scotland.
Have managed to get the tracking and Camber set up myself but am not too sure about tackling the castor angle. Any hints on how to go about this??*tired*
are you using the mintec gauge? if so.....
there are angled lines on the one side of the board (60deg), sit this so the edge is parallel to the wheel and turn the steering so that the wheel is is parallel to one of these lines
measure the castor the same way as you would the camber, but use the numbers in the middle of the gauge.
Then turn the wheels so that they are parallel to the other diagonal line and measure again.
Add the 2 values again and then you have your castor
To increase the castor angle shorten the ties, to decrease lengthen
bawbee
Member #: 191
Falkirk, Scotland.
Actualy did the camber with a homemade gauge using a pendulum and a calibrated scale. Was hoping to make up something for the castor angle but will have to have a think about it. Thanks anyway.
