| Home > General Chat > minisport alloy 4 pots flanges | |||||||
![]() 265 Posts Member #: 10512 Senior Member whitby, north yorkshire |
24th Sep, 2013 at 04:36:37pm
can you use the standard flangles of a 8.4 brake setup with the 7.9 minisport 4 pots calipers? also are the alloy flanges worth buying for the weight saving |
24th Sep, 2013 at 04:44:15pm
Yes and yes Drives
24th Sep, 2013 at 05:14:51pm
I have normal flanges on my 7.9 vented set up the 7.9s are turned down 8.4s
Yes i moved to the darkside |
24th Sep, 2013 at 05:44:49pm
cheers will these fitwith the 7.9 vented ones then? http://www.minisport.com/21a2695a-mini-spo...-disc-type.html |
24th Sep, 2013 at 08:51:15pm
Why do you want 7.9? I seriously doubt it! |
24th Sep, 2013 at 08:55:15pm
for 10" wheels |
24th Sep, 2013 at 08:56:24pm
Go for 7.5 then and save more weight I seriously doubt it! |
24th Sep, 2013 at 09:01:24pm
7.5 brake kit is more expensive at the moment than 7.9 vented ones on minisport duno how they work that out though ahah |
24th Sep, 2013 at 09:10:13pm
Buy Minispares alloy S callipers and turn down some 8.4 disks to 7.5 I seriously doubt it! |
24th Sep, 2013 at 09:16:46pm
can do that once its back on the road and all the main stuff is done when i sort all the small bits, same with the flanges really now i thin about it just the standard ones weight a ton |
minus vented as you will need vented flanges
