| Home > Help Needed / General Tech Chat > MG Metro Turbo distributor oil leak | |||||||
69 Posts Member #: 2974 Advanced Member |
26th Sep, 2013 at 08:52:02pm
Hi all,
Edited by JC T ONE on 26th Sep, 2013. |
26th Sep, 2013 at 10:36:04pm
yes the seals perished you can get new ones.
26th Sep, 2013 at 11:29:13pm
On 26th Sep, 2013 BENROSS said:
yes the seals perished you can get new ones. Thanks for your helpfull reply. ( nice video,s ) Your reply leeds to a new question = who has spares for these distributors ? |
27th Sep, 2013 at 09:26:35am
On the distubutors I dismantled (to make phase sensors for my fuel injection system) there were/are no seals on the shaft. Mine were earlier points type (but still A+) but I doubt they changed that part of the design when they went electronic (I've had an electronic one apart and don't remember that part being different but I only have photos of the points type shaft).
27th Sep, 2013 at 06:37:48pm
What about the dipstick? does the engine breathe heavy? or is the breather system adequate or blocked? Its common from time to time for big bore engines to eject oil out through the dipstick tube which is why you see a spring from the dizzy clamp to the top of the dipstick from time to time. On 26th Oct, 2004 TurboDave16v said:
28th Sep, 2013 at 02:54:32am
Hi all,
Edited by JC T ONE on 28th Sep, 2013. |
28th Sep, 2013 at 06:23:30am
On 28th Sep, 2013 JC T ONE said:
There is no play in the shaft, so maybe the "spiral" that should push the oil back, is dirty/filled up with sod . Possibly. Here's a couple of piccys to help. As I said before, piccys are of the mechanical A+ but I don't remember the electronic one I took apart being any different bearing wise, I just don't have any piccys to confirm it.... Dismantled (and body chopped in half for my mod) and you can see the spiral on the bottom of the shaft.
And the next one clearly shows the offset roll pin that holds it all together. It also shows the oil feed hole (just below the O ring groove) Before you dismantle it, it might be worth spraying carb or brake cleaner in that hole with the dizzy held vertically and making sure it runs out the bottom above the drive dog which might help clean the spiral if it is clogged up.
