| Home > Help Needed / General Tech Chat > Omega Piston CC | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
30th Sep, 2013 at 07:36:08am
the time has come to start ordering internals for the mini :)
30th Sep, 2013 at 08:54:10am
I had 10cc cast omegas and 28cc in the head and about 0.5mm deck hight 16psi no problem
Yes i moved to the darkside |
30th Sep, 2013 at 09:08:47am
there's always scope for more boost On 30th Sep, 2013 Brett said:
I had 10cc cast omegas and 28cc in the head and about 0.5mm deck hight 16psi no problem If you garentee your self not to want more boost i personaly would run a little more compression maybe 8.5-8.7 probably make naf all differance tbh the final tune is where the benefits might be seen What the mind can conceive the mini can achieve
30th Sep, 2013 at 09:16:47am
We ran about 8.3:1 in the metro van with as much boost as we could throw at it on standard pistons. On 11th Feb, 2015 robert said:
30th Sep, 2013 at 09:33:13am
8.16:1 If something is worth doing, it's worth doing half of. |
30th Sep, 2013 at 09:36:36am
30th Sep, 2013 at 11:38:38am
cheers guy's
On 30th Sep, 2013 John said:
8.16:1 ![]() What the mind can conceive the mini can achieve
