| Home > Help Needed / General Tech Chat > Downpipe fitting issue | |||||||
90 Posts Member #: 10229 Advanced Member Stroud |
30th Sep, 2013 at 02:52:08pm
Just gone to fit my Maniflow 2" downpipe onto my standard T3 outlet but im struggling for room a little. The downpipe is heat wrapped but its touching the inboard pot/cv joint. I am yet to clamp it up tight yet because i wanted to check im not missing a trick first. Is this normal? Cheers. |
30th Sep, 2013 at 03:00:18pm
You should be able to get a quarter inch either side of it, they are tight but it will go. |
389 Posts Member #: 9751 Senior Member Derbyshire |
30th Sep, 2013 at 03:00:53pm
i fitted a 2" downpipe to my gt17 build and had to 'modify' it as it was also touching the cv.
30th Sep, 2013 at 03:23:10pm
Panic over. Removed the heat wrap and it fits. Just. Thanks anyway guys. |
