| Home > General Chat > Pushrod hole & Pushrods | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
2nd Oct, 2013 at 08:45:06pm
Can anyone shed light as to why No 1 & 8 pushrod holes are a larger Dia at the top 40mm ?
5th Oct, 2013 at 09:26:52am
Leave well a loan, is my advice......... STD pushrods are well up to the job....... no unnessasary money spent in the wrong department. IMO........
5th Oct, 2013 at 01:59:27pm
Why do you say that Benross? With the high lifts that we are using in N/A with high revs surely a stiffer pushrod is an advantage but they do necessitate a larger pushrod hole I seriously doubt it! |
5th Oct, 2013 at 02:18:32pm
For what it's worth, the answer to the original question - why are the casting holes different sizes - is probably because the designer could make the outer ones bigger without challenging other voids in the casting (waterways/ports).
6th Oct, 2013 at 11:33:56am
what is the spacing between the outermost valve centres and the outermost pushrod centres? Perhaps the valves are further apart and the pushrods are angled ever so slightly? If not, then it is as Rod suggested - just to keep consistency with wall thickness, which from a design perspective is a personal preference thing... On 17th Nov, 2014 Tom Fenton said:
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
6th Oct, 2013 at 01:34:24pm
or maybe those the are for locating dowels during block machining . |
