| Home > Help Needed / General Tech Chat > using an spi engine for....something else! | |||||||
24 Posts Member #: 10591 Member Manchester |
4th Oct, 2013 at 10:00:59pm
Hi guys just wondering if some of the more knowledgeable people can help me a bit. I currently have an spi mini which i have begun to strip back. Im going to get rid of some of the excess parts as i want to take it back to carb or possibly turbo it. Will there be many hinderances along the way? I believe the piston rings are different but im going to eventually have the engine rebuilt before the build anyway so that shouldnt be much of a problem. I have a fairly competant auto elecy to help with the wiring loom (albeit not a mini enthusiast). Any help would be appreciated guys! Thanks in advance |
5th Oct, 2013 at 09:01:52am
Once you pull the fuel injection stuff off just treat it as a normal 1275cc engine and do what you like with it On 26th Jan, 2012 Tom Fenton said:
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
5th Oct, 2013 at 10:56:04am
convert a few back to hif44 with no issues.
5th Oct, 2013 at 12:27:34pm
we turned an spi setup to run carb/ turbo / megajolt in about a day. not too hard, with the correct heynes diagram.
Edited by welshdan on 5th Oct, 2013. |
5th Oct, 2013 at 01:05:42pm
The only difference I found as such apart from all the obvious stuff was actually the transfer case of the gear box Yes i moved to the darkside |
5th Oct, 2013 at 04:52:56pm
Also the oil filter supply union in the block is a different thread On 11th Feb, 2015 robert said:
5th Oct, 2013 at 05:50:57pm
Will the oil filter matter as i can just keep the filter housing surely? Thanks for the input guys keep them coming! :) |
5th Oct, 2013 at 06:04:00pm
It makes no odd's, just worth bearing in mind. On 11th Feb, 2015 robert said:
