Home > Technical Chat > problem with fuel
kevin squires
Member #: 10574
clevedon
hi can anyone help I have a classic mini turbo and its started cutting out when u pull up at a junction. if I try to start it wont start if I disconnect the fuel pump it will start and run fine in till it runs out of fuel, if I re connect the pump it will start and then do the some thing again, it runs fine on the motor way just when u stop and the car is idleing ????????????????????????????? please help*angry*
Nick 91
Member #: 10037
Caterham
Maybe flooding?
Might be worth checking your fuel pressure ( http://www.ebay.co.uk/itm/Fuel-Pressure-Ga...90#ht_755wt_869 )/ return line condition.
Had something similar due to squished fuel lines restricting the return.
Edited by Nick 91 on 5th Oct, 2013.
kevin squires
Member #: 10574
clevedon
The plugs arnt wet so I ruledout flooding I will check the fuel line in the morning . Slark only set everything up for me a few weeks ago it the first time I have driven the car took it for an mot all fine then started cutting out many thanks
kevin squires
Member #: 10574
clevedon
There was a kink in the pipe but still got the same problem when the pump is connected it cuts out ???????? Help anyone
Have you got the regulator plumbed in properly?
kevin squires
Member #: 10574
clevedon
thanks for the reply's the regulator is all plumbed in aok runs fine with pump off soon as pump is put on when the car is running it cuts out. what do u mean by ring friction the engine has only done around 50 miles
Float valve?
kevin squires
Member #: 10574
clevedon
What do u mean grow up when u say ring friction I think piston ring not float valve thanks anyway I will look tomorrow
Lol. Those are both signatures, not responses :)
