| Home > Help Needed / General Tech Chat > 1275 eletric fans | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
5th Oct, 2013 at 08:07:47pm
I cant work out which way the fan should spin, the standard electric fan on 1275 should it blow into the rad or should it suck the hot air into the wheel ache? |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
5th Oct, 2013 at 08:25:47pm
suck hot air into the wheel arch What the mind can conceive the mini can achieve
6th Oct, 2013 at 08:02:04pm
are you sure? |
6th Oct, 2013 at 08:27:28pm
Yes he's right, otherwise it would cancel out the mechanical fan and not a lot would happen and it would overheat! On 26th Jan, 2012 Tom Fenton said:
7th Oct, 2013 at 06:41:42am
Yep On 6th Oct, 2013 Zeemax Power said:
are you sure? Edited by lee.pb on 7th Oct, 2013. What the mind can conceive the mini can achieve
7th Oct, 2013 at 09:14:10am
also check out your fan shroud and related body rubber are directing air flow where it needs to go
7th Oct, 2013 at 07:07:21pm
thank you for help! |
8th Oct, 2013 at 07:13:47am
the fan can also be fitted 2 ways, something else to check What the mind can conceive the mini can achieve
as carzilla says the mechancal blows through the rad.
