Home > General Chat > dual fuel tanks/supplys with regular and race gas
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
so im just watching you tube seen this thought its nice how they cruse on 91 little or no load and has 116 for more load/boost surely its the way to go for long term running/set up costs involved?
so i guess what im asking is there any reason why we cant do this on our minis? i think its a good idea although i dont really have a clue haha
whats involved with setting this up?
two separate parallel fuel systems to start with inc tank lines pumps regs injectors the lot
second signal from ms to turn the pump on at desired map settings
second tables fuel spark and so on
skip to 1:50 and 3:20 if you like
http://www.youtube.com/watch?v=KB1Wrv0SiyQ
If you're running a carb that's not of any use, because when you boot it you're still running on the supply of fuel in the float bowl and then likely to cause damage to the engine.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
sorry i should have said if i was to do this dual fuel id be on efi for the reason you have pointed out
Are you already pushing the limits of pump fuel ?
IMO there are cheaper and easier alternatives to race fuel under most circumstances. Especially if it involves the complication of two complete fuel systems.
on something like a mini the extra weight is going to be an issue,
