| Home > General Chat > AEM Failsafe (boost and AFR parameter alerting) | |||||||
7th Oct, 2013 at 01:39:41am
Don't know how long this has been around. Seems like a good idea - obviously still needs some common sense in setting up to work correctly!
93 Posts Member #: 9597 Advanced Member |
8th Oct, 2013 at 07:18:02pm
I have this gauge, it's pretty good. I mostly got it for the data logging. I'm not clever enough to make much use of it yet but it looks cool with a laptop plugged into it and that's what counts! |
![]() 270 Posts Member #: 69 Senior Member Coventry |
8th May, 2014 at 08:37:39pm
Been doing a little research into AFR gauges over last couple of days and came across the AEM failsafe, looks an awful lot more gauge than the normal AEM wideband AFR gauge, I like the vacuum feature and the datalogging, how have you got on with it. |
11th May, 2014 at 06:53:29am
I got this. Again, more for the data logging. Does what it says on the tin and I'd definitely recommend it |
4th Jul, 2014 at 08:42:34pm
Hi got one and fitted it but getting a flaky RPM reading, Running a dizzy and took the negative side of coil as using a luminition ignitor, Paperwork suggests it needs a square wave RPM signal, which this isnt? Has anyone got this to work if so how... |
