Home > Help Needed / General Tech Chat > Fuel pump (again)
paul25
Member #: 596
Sorry Guys...
I am testing my wiring harness after making over 50% and fitting it to the vehicle. As such the starter motor is wired up and propped up on a piece of wood! I need to test the fuel pump relay, but cannot remember which terminal on the starter the feed should be connected to. (I have wired the fuel pump as per ERA)
I don't want to have to turn the starter over too many times if possible!
hi paul and welcome to turbo minis
you should follow the drawing of the wiring more closley .....
but if not you will need a VOLT meter.
find the LIVE!! wire when the ignition is in the ON position.
and the engine is NOT been cranked over
when the ignition switch is ON for run ! ( find that LIVE!! wire)
thats the wire you need.*wink*
Edited by BENROSS on 19th Jul, 2005.
