| Home > Beginners Tech > Brake servo removal | |||||||
24 Posts Member #: 10591 Member Manchester |
7th Oct, 2013 at 06:50:13pm
Hi guys iv searched the forums and not been able to find anything. Is there a trick im missing with removing the brake servo. One of the bolts has sheared on the bulkhead but it doesnt seem like its affecting it. Do i need to remove the pedal box before getting the servo off? Thanks in advance |
7th Oct, 2013 at 07:07:31pm
Have you removed the clevis pin through the pedal? On 11th Feb, 2015 robert said:
7th Oct, 2013 at 07:30:15pm
Yes mate iv removed that removed the bolt thats on the back of the dash and like i said the one on the bulkhead has sheared but it doesnt seem to be obstructing it. The bulkhead is in a bit of a state around that area im thinking maybe its not been removed for a looooong time and its just being awkward. Do i need to remove the pedals and pedal box? |
7th Oct, 2013 at 08:48:02pm
No. You just need to remove the Clevis pin at the back, the top bolt on the bulkhead and the two on the crossmember. The studs are part of the pedal box, so that will have to come out if you've broken one. In the 13's at last!.. Just |
7th Oct, 2013 at 08:52:13pm
Remove the master cylinders (brake and clutch) after removing both clevis pins from inside the car, undo the bolt on the bulkhead and it should all pull up and off easily. After typing that I'm not sure if you have to remove the clutch master, disregard it if none of it is bolted to the servo bracket! On 26th Jan, 2012 Tom Fenton said:
7th Oct, 2013 at 08:55:32pm
The clutch master doesn't need to be removed to get the servo out. In the 13's at last!.. Just |
7th Oct, 2013 at 09:02:02pm
It's been a few months since i last took one out but I was also taking everything out because i was stripping one down for blasting for a mate, so there you go, pretty simple! On 26th Jan, 2012 Tom Fenton said:
8th Oct, 2013 at 09:00:25am
I think theres a bolt hiding beneath the clutch cylinder had a quick look last night going to see when i get home later |
8th Oct, 2013 at 09:52:05am
which servo have you got? if it is the late model one, you only need to disconnect the control arm from the brake pedal in the lever above the bulkhead - I'm pretty sure the other end of this control rod is riveted to the brake pedal anyway so no clevis pin inside the car. There is a nut and bolt going through the bulkhead (behind the dash as you mentioned), and it is bolted down to the pedal box with 2 nuts (next to the clutch master). You mentioned one bolt shearing but not removing a second?
8th Oct, 2013 at 11:17:24am
Yes i think iv missed the second bolt hiding beneath the clutch master cylinder looks in a bad state could possibly have 2 sheared bolts later haha. Any tips on gettin realllllyy rusty nuts off without damage? |
8th Oct, 2013 at 01:19:10pm
plenty of penetrating oil |
