Home > Technical Chat > Sc drop gears!
Alex Gibson
Member #: 7760
Just about to fit my sc drop gears when I noticed something wrong with the idle gear! The shaft has a lot smaller diameter than the bearing it is meant to fit! Does this mean I have a series drop gear when I need A+ gears or an I missing somthing?
Yes, you have got pre A+ drops
Alex Gibson
Member #: 7760
Cheers Paul!
mini spares do (did?) a convertor bearing to go from A+ cas to A drop gear.
Amp
Member #: 7856
I believe this should be the one:
Edited by Amp on 7th Oct, 2013.
well done that man!
not cheap though...
