| Home > Help Needed / General Tech Chat > emmisions(how to work round them) | |||||||
24 Posts Member #: 10591 Member Manchester |
12th Oct, 2013 at 11:01:16pm
Hi guys just wondering how you all get on with emmisions when MoTing your turbo minis. Im currently planning a turbo build with my mini which is a 96/97 spi but emmisions changed in 92/93 didnt they. What sort of solutions would i have for this problem? Thanks in advance guys!! |
12th Oct, 2013 at 11:53:14pm
i think some of the guys have used a lean tune and idled the car to and from mot
13th Oct, 2013 at 08:55:16pm
Check the Frequently Asked Questions for emissions regs On 26th Oct, 2004 TurboDave16v said:
13th Oct, 2013 at 10:40:22pm
On 12th Oct, 2013 timymontana said:
Hi guys just wondering how you all get on with emmisions when MoTing your turbo minis. Im currently planning a turbo build with my mini which is a 96/97 spi but emmisions changed in 92/93 didnt they. What sort of solutions would i have for this problem? Thanks in advance guys!! If you are retaining fuel injection and a mild or standard camshaft, catalytic convertor etc....you should have no problem. If you are reverting back to a carburettor, then via engine numbers, headed letters etc etc. If you can prove the engine fitted to the car is older than the 92 CAT test rules, you will be tested as per an older engine. 9.85 @ 145mph
13th Oct, 2013 at 10:59:59pm
Hi guys just wondering how you all get on with emmisions when MoTing your turbo minis. Im currently planning a turbo build with my mini which is a 96/97 spi but emmisions changed in 92/93 didnt they. What sort of solutions would i have for this problem? Thanks in advance guys!! If you are retaining fuel injection and a mild or standard camshaft, catalytic convertor etc....you should have no problem. If you are reverting back to a carburettor, then via engine numbers, headed letters etc etc. If you can prove the engine fitted to the car is older than the 92 CAT test rules, you will be tested as per an older engine. Not on the Mini. The Mini has vehicle specific emissions limits that vary from the normal 'cat' test. The main reason for this was that rover were still selling carburetor models right up until early 1995 alongside the Injection models. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=462092 Edited by Sprocket on 13th Oct, 2013. On 26th Oct, 2004 TurboDave16v said:
14th Oct, 2013 at 07:44:18pm
I just tweeked my carb down a turn and it was perfect. Then put it back after the mot 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
