Home > Help Needed / General Tech Chat > air fuel ratio guage and charge temperature guage and sensors
1275min
Member #: 538
Frimley, Surrey
Hi Chaps,
As some of you might know I have had a few issues with the engine leaning out this season. So while its of the road for the winter I want to fit a lamber sensor and a sensor in the plenum so I can see whats going on without the expensive trips to the rolling road as well as fitting an intercooler
Have any of you got any suggestions with regards to gauges and sensors to use?
Im also after a smallish intercooler with outlets at the top.
rich13801
Member #: 2150
Vems does both Lambda/AFR and EGT, a little more expansive than the others. But you only need the one gauge, instead of two.
https://shop.vems.hu/catalog/round-wbo2-gau...05¤cy=GBP
