| Home > Help Needed / General Tech Chat > Bouncing Fuel Pressure. | |||||||
107 Posts Member #: 2556 Advanced Member Southport, Merseyside |
18th Oct, 2013 at 06:11:52am
Just out of curiosity, does anyone elses fuel pressure bounce when the ignition is on? Mine seems to hold 4 psi while the ignition is off and no power to the pump for a while then slowly drops off, but with the ignition on it bounces between 3 and 5 psi on the gauge. I'm just using a cheap fuel pressure gauge and is plumbed in right between the inlet to the carb and the regulator.
18th Oct, 2013 at 07:08:03am
I have seen this a couple times with old regulators a couple psi on a carb is nothing to worry about imo Yes i moved to the darkside |
18th Oct, 2013 at 09:22:45am
my facet pump? (makes a tic tic sound) got some grit stuck in it once and it didn't hold pressure the result was pulsing fuel pressure like you have by the sounds i just cleaned out the top part on my pump (the valve bits) and all was well think it was just one of the gates stuck open so not letting the pump hold pressure altho it still got up to pressure it just droped off between pump diafram movements |
18th Oct, 2013 at 09:38:03am
Thank you both for the info. I think i'll give the regulator and pump a good clean out and see if it steadies it out a bit. If its not something to worry about then i'll tick it off the long list of possible misfire causes! Thanks! |
18th Oct, 2013 at 10:15:51am
i should add that what i experienced had no apparent affect just like Brett has also said
