Home > General Chat > one for the chippys
I have just started changing my internal house doors to oak veneer jobbies
The first door i have installed has gone swimmingly well apart from where i cut it down i got slight splintering, i used a fine tooth blade and lisa says its hardly noticable however i have another i need to take 10mm off top and bottom so would like ideas on how to stop this, a plane is not a good idea in my hands unless i am taking off 1-2 mm only
oli79
Member #: 8480
Not a chippy by any means, could clamp a sheet/piece of scrap timber to the edge of the door under the cut, ie cut through the door and the sacrificial piece. From having worked around and casually observed joiners I would say they cut doors to 2/3mm oversize anyhow and then plane them up to finished size to remove the spelching, planing from each end into the middle to avoid chipping a large lump off the run off end, when working on end grain, someone who knows may have a better idea.
Edited by oli79 on 18th Oct, 2013.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
oli79
Member #: 8480
Maybe you should wait for another of our kamikaze kitchen fitters to advertise and ask them lol *hehe!*
liam mini 35
Member #: 9125
Sheffield, South Yorkshire
Are the doors solid?
The turbo build has finally started
They are solid with a 20mm oak veneer all around
These doors
http://www.howdens.com/doors-joinery-colle.../worcester-oak/
1380rich
Member #: 9766
Warwickshire
Probably worth getting someone with a decent circular to cut them to size if you want them perfect without messing around with a plane. I've got one of these http://www.festool.co.uk/products/pages/pr...plus-fs-gb-240v cuts so clean its like a factory finish.
Avon 2010 class c 3rd
I would use an axe.
Chainsaw angle grinder disc? *tongue* (Not being serious)
Jawd
Member #: 10212
Sleaford Lincolnshire
Wolfie
If you score the cut line with a craft knife first then cut with the saw on the waste side of the line this should stop the splintering mate
GL Jawd
philc
Member #: 1346
bromsgrove
get a decent cutting blade with a fine cut
scott the joiner
Member #: 9229
newcastle upon tyne
i know u said you dont like the plane but thats all i use well electric one lol but set the depth to a couple mm & just make a few passes but as said above working from one side to centre then flip over the door & go from the other side
Cod and chips with curry sauce please.... Oh hang on wrong kind of chippy....
i have splashed out on a posh fine cut cross cut freud blade i will give it a pop over the weekend with the other ideas combined
Rick.SPI
Member #: 8027
A little bit of masking tape either side can help more than you would imagine (if we are on about a lamiated door and not a solid jobby.
