| Home > Help Needed / General Tech Chat > Verto hub bolts upgrade | |||||||
18th Oct, 2013 at 09:47:18pm
I've been stripping my clutch today, and it looks like my hub retaining bolts and threads in the carrier plate are looking a bit worse for wear, even though the threads were perfect on installation and new bolts used. Edited by matty on 18th Oct, 2013. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
18th Oct, 2013 at 09:51:07pm
12x1.25 is another option quite often used in automotive applications
19th Oct, 2013 at 09:00:52am
Any idea on what vehicles to look for using 1.25?
19th Oct, 2013 at 11:56:30am
Why not a unf thread? I seriously doubt it! |
19th Oct, 2013 at 04:18:33pm
I could use unf, but at work we have an abundance of fine metric taps and thought it would be easier to find a metric bolt.
19th Oct, 2013 at 05:30:53pm
What about dowelling the center to the plate in the three places not used for the puller and just use a grade 12.9 cap head or better still NAS bolts.
Edited by Sprocket on 19th Oct, 2013. On 26th Oct, 2004 TurboDave16v said:
27th Oct, 2013 at 01:33:01pm
D you know if there is enough clearance to use cap heads? I'm sure I remember someone saying they catch the friction plate...could be wrong though. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Oct, 2013 at 07:38:17pm
you can get reduced head ones
27th Oct, 2013 at 09:07:54pm
Most jap cars use m12x1.25 for chassis and suspension, flywheels are often mwhateverx1mm or so turbo 16v k-series 11.9@118.9 :)
27th Oct, 2013 at 10:20:44pm
Ah ha these look perfect!
27th Oct, 2013 at 10:23:10pm
Three different lengths in the range you are looking for. There are others longer if you want them
27th Oct, 2013 at 10:31:06pm
or in M10 x1.25
27th Oct, 2013 at 10:31:11pm
Yeah 15mm may be cutting it fine. I'll have to have a measure up. At least I know where to look now, quite a few for mitsubishi cars on eBay too in the uk. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jan, 2014 at 10:04:18pm
Mission complete! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jan, 2014 at 10:22:28pm
nicely done!
9th Jan, 2014 at 10:27:19pm
very good,
9th Jan, 2014 at 10:40:47pm
nice Yes i moved to the darkside |
9th Jan, 2014 at 11:47:02pm
All clearance holes were drilled to 12mm and I used M12 X 1.25 X 15mm bolts, so absolutely no chance of fretting. I lapped the mating faces together, and used high strength locktite on the bolts...it'll be a fucker to take apart now. Lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Jan, 2014 at 07:49:15am
Just use heat on the bolts when you want to take it appart. That softens up the thread lock. On 26th Oct, 2004 TurboDave16v said:
