Home > Help Needed / General Tech Chat > Disconnecting Vacuum advance pipe. Any advantages / disadvantages?
holmesgraham
Member #: 2556
Southport, Merseyside
Is this common practice? What are the reasons people do this?
Thanks
Graham
dazibee
Member #: 1356
TRURO, CORNWALL
Advantage having it connected on a road car is better mpg. There is no reason not to have it. It may be disconnected to mask other problems
Edited by dazibee on 19th Oct, 2013.
When running a dissy on a turbo lump, some people disconnect the vac advance (amongst other things) to fix the ignition timing at a set number.
On 19th Oct, 2013 dazibee said:
Advantage on a road car is better mpg. There is no reason not to have it. It may be disconnected to mask other problems
Thats not right. MPG will drop off!
on cruse you want a lot of advance, and that is what the vac unit does. Run with a low advance on cruse andd you'll need more throttle for the same torque required to keep the car moving along at a constant speed. Increase the advance, thus increasing the torque, you then need to use less throttle to stay at the same speed. Less throttle, less air, less fuel.....................
dazibee
Member #: 1356
TRURO, CORNWALL
My first post was confusing, now edited it
Now I look a right twat lol *tongue* *wink**wink*
