| Home > Beginners Tech > Fuel T-Fitting Estate and other questions | |||||||
![]() 22 Posts Member #: 10615 Member Maryland, USA |
19th Oct, 2013 at 02:21:12pm
I am going to be using the weber dgv carb with a rhb31 turbo. I got almost everything together but have a few small details. For the fuel side I was going to use a External Inline fuel pump at Free Flow Rate:43 gph Maximum Pressure (psi):45 psi Inlet Size:5/16 in.Inlet Outlet Size:5/16 in.
19th Oct, 2013 at 04:15:52pm
Will this do? Or should I get a thread to thread, then into the t? Basically so I want to remove the threaded in hard line to the tank and put the t there, or can I add this shortly after? Cheers.
20th Oct, 2013 at 06:54:20am
my understanding of fuel lines is its better to have feed and return the same size due to any back pressure/resistance that could arise on the return your reg may not do its job fully if this is the case also if your running one line why not run two?
20th Oct, 2013 at 07:03:39am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=459785 On 11th Feb, 2015 robert said:
21st Oct, 2013 at 12:19:11pm
Yes I saw that thread, I would like to do an in tank pump, but inline will have to do for now till spring. I have a LP Pump and HP Pump with a fuel accumulator on my Morris Minor, it works, but I just don't like the idea of having two pumps. One day that will be revisited as well. Thanks. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
21st Oct, 2013 at 06:03:50pm
Talking to SC yesterday, they told me to use the standard feed line as it is, and just plumb in a very short return at the tank. Metric is for people who can't do fractions. |
