Home > Technical Chat > Using megajolt building a kit or buying one
miniclubmanman
Member #: 7124
emsworth somewere near portsmouth
Hey guys gonna be doing a turbo build soon enough but the question I have is would you buy a megajolt kit http://bit.ly/11kbdJQ or would you build one up collectin parts.
Has anybody got one of those kits off eBay? If so where they any good.
Shaun
wow how much?
coilpack edis and leads came from the scrap yard for me £20
even new from a motor factors would be cheaper i think
miniclubmanman
Member #: 7124
Yeah I was wondering that is there anyone on the forum who can supply a new megajolt?
lee.pb
Member #: 9199
Lancashire
i got a complete kit for £200.
dont be worried about buying a tps version as its only £20 to convert
miniclubmanman
Member #: 7124
Ok that's good to know :) did not know if they could be converted.
Thank you
lee.pb
Member #: 9199
Lancashire
you just need a MAP sensor from RS and a couple of resistor's and a capacitor.
if you need the resistor's and the capacitor i already have spare's as could only by in 10's *surprised*
you also need to desolder a resistor off the TPS section of the board and thats it.
Thank you
miniclubmanman
Member #: 7124
Ok that's excellent if I only find a cheap tps one then I'll grab them off you? :)
lee.pb
Member #: 9199
Lancashire
you'll also need one of these.
http://uk.rs-online.com/web/p/pressure-sensors/7191074/
its R6 resister you need to remove from the TPS section to disable it.
miniclubmanman
Member #: 7124
Thank you
jakejakejake1
Member #: 10010
Northants
the whole kit:
http://www.autosportlabs.com/mjlj-conversion-p-50.html
I have a few extra of the required capacitors and resistors kicking about if anyone needs them. But you will still require one of these pressure sensors:
http://www.ebay.co.uk/itm/IC-SENSOR-ABS-PR...=item5af27131bc
Nial
Member #: 9073
Edinburgh
The pressure sensor is cheaper from Farnell.....
http://uk.farnell.com/freescale-semiconduc...3?Ntt=MPX4250AP
I think they have £20 minimum for card payments but you can probably make that up with wire/ solder/ heat shrink / tools etc!
Nial
miniclubmanman
Member #: 7124
Thanks for all that guys :) has anybody got the kit off eBay before?
jakejakejake1
Member #: 10010
Northants
There is probably not many people who have, if you go to their website
(http://trigger-wheels.com/store/) you can build your own kit on there and leave out the bits you can get cheap elsewhere. I.e. the megajolt alone from them is only £130ish
lee.pb
Member #: 9199
Lancashire
mate looking to some trigger wheel bits if your interested.
chinlesswonder
Member #: 1192
In the garage......again!!
I bought that kit for my turbo, it does not come with the centre bolt to hold the damper on the crank, you cant use the existing one as its not long enough after fitting the trigger wheel, I bought the recommended bolt to hold it all together for £20, it is an allen key to tighten up. Mine came loose the other week even with lots of locktight on it as you cant get decent leverage.
I would suggest a machined damper.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
miniclubmanman
Member #: 7124
Only just saw people have wrote back on here :/ yeah I will go on the web site later and have a look and thank you about the damper info. The only reason I was looking at it, that it is a compleate kit and not gonna have to find any bits, but if I can save a decent amount of money buying it in parts ill do it that way. Before I do a wanted thread does anybody have a megajolt kit a map version for sale :)
miniclubmanman
Member #: 7124
Also did u buy the loom made or made one your self :)
Edited by miniclubmanman on 27th Oct, 2013.
lee.pb
Member #: 9199
Lancashire
you have to make the looms, i made 2 at the same time.
quite simple to do once you know where your MJ / Edis4 and coil pack is going.
miniclubmanman
Member #: 7124
Ok dokie, just when I was on Twigger wheels? They said they could make looms and was not sure what was the better way to do it, just looked at some wiring diagrams so hopefully should not be to bad to do :)
lee.pb
Member #: 9199
Lancashire
the basic loom is simple to do.
edis 4 connections:
2 wires to vr sensor (screened)
3 wires to coil pack
pip/saw to mj (screened)
ignition positive
ground
rev counter signal
mj connections:
pip/saw from edis4 (screened)
ign postive
ground
think thats it, all other outputs and inputs connect to mj if you want them
miniclubmanman
Member #: 7124
Ok thank you :)
