| Home > Help Needed / General Tech Chat > bonding carbon sheet with fiberglass | |||||||
29th Oct, 2013 at 08:14:05pm
I have had a look around but not found anything that helpful. I have some carbon sheet and two different designs I want tomake out of it, cutting is fine but I dont know how to bond them together Drives
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
29th Oct, 2013 at 08:32:07pm
First abrade with p120. Then a scotchbrite pad.
This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
29th Oct, 2013 at 08:43:04pm
Alternatively, if you have access to bagging film or release film.
29th Oct, 2013 at 08:49:21pm
Cheers steve, I have some fg to play with so sounds like a plan, I was going to try and keep it clean at the front and do all the back work at the back (tape and clear silicone seel the front so it can be wet layed on the back) I have all the correct dimensions and just a little bit of masking tape its very rigid to fg onto. Drives
29th Oct, 2013 at 08:52:22pm
I have some ptfe tape here that will do the job better than the silicone and tape.
29th Oct, 2013 at 08:53:08pm
Cant you just glue it? I seriously doubt it! |
29th Oct, 2013 at 08:55:22pm
I was thinking just at the joins as it is clear and can done quite mess free, I have alot of ptfe left from putting in a mew shower. I will check the resin I have Drives
. Any tips would be awsome
