Home > Beginners Tech > Pre-A+ gearbox on A+
vegar
Member #: 189
Could anybody please tell me if a DAM3220 A gearbox fit on a 998 A+ engine, and does this require any special parts?
Chers
www.shag.no
As long as you have the matching transfer case then gearboxes and engines are interchangeable with each other :)
vegar
Member #: 189
Thanx mate :)
www.shag.no
and as long as you have the correct drops, ie the ones from the 998 engine.
vegar
Member #: 189
This is when I start to get worried. The drops are sc but I have no idea of wich type. It was supposed to be a complet dissmantled A+, but are missing a lot of the + parts....
www.shag.no
well there are the different idler bearing diameters, A and A+... and the different primarys for 998 and 1275, although you can bush the 1275 primary down to fit the 998 crank...
there are different tooth profiles for helicals and different ratio's too, but you dont need to be concerned with that.
vegar
Member #: 189
The primary are missing, along with some other parts. I am trying to make a list of missing parts atm
www.shag.no
Alex
Member #: 1851
Woolavington, Zummerzet
There is a thick wall bearing available to reduce the diameter of an A+ transfer case to pre-A+ size to match the gearbox.
vegar
Member #: 189
The drop gears are from minispares, but I can only find to 1275 sc.
I have a set of orginal drop gears from an 1275GT. Can use this with the bush you mention?
www.shag.no
