| Home > General Chat > Brake rotor material | |||||||
30th Oct, 2013 at 05:43:17pm
A conversation at work today sparked this - Supposedly cast iron is best and is most commonly used but Strange Engineering make them from forged steel, would steel plate be upto the job for a Mini used on the 1/4 mile only? 7.5" diameter and 5.16"/8mm thick I seriously doubt it! |
30th Oct, 2013 at 06:05:24pm
Hmmm,
30th Oct, 2013 at 07:10:33pm
When you mean rotor do you mean the disc? or the Hub style? where the disc bolts too?
30th Oct, 2013 at 07:34:19pm
He's being Americanist, lol disc is what he means ,
30th Oct, 2013 at 08:00:31pm
Always thought they were cast iron |
30th Oct, 2013 at 08:58:54pm
Carbon ceramic disks? Surely there are dragsters with tiney brakes out there? Drives
31st Oct, 2013 at 07:19:50am
None that I can find Paul I seriously doubt it! |
614 Posts Member #: 2153 Post Whore kings langley |
31st Oct, 2013 at 07:48:56am
What about going back to a drum setup? With aluminium drums shaved down and drilled? Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
261 Posts Member #: 713 Senior Member Western Australia |
31st Oct, 2013 at 07:59:53am
Steel discs are used on speedway cars, and they have even more h.p. than Paul!
Edited by AWDmoke on 31st Oct, 2013. On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
31st Oct, 2013 at 08:05:49am
On 31st Oct, 2013 supermotolee said:
What about going back to a drum setup? With aluminium drums shaved down and drilled? That would add loads of weight, but we were only talking about whether steel is upto the job - not losing weight I seriously doubt it! |
31st Oct, 2013 at 08:12:25am
Are not most motorbike disks stainless? So long as you match the disk material with the friction material it should be fine.
http://www.twin-turbo.co.uk
31st Oct, 2013 at 08:27:31am
Thinking about this, if its just 1/4 mile you'll prbably be fine with most stuff including ally. On 28th Aug, 2011 Kean said:
31st Oct, 2013 at 08:31:19am
It's a shame the smallest Wilwood ally discs are 10.2"
1st Nov, 2013 at 06:22:49pm
Wilwood's drag stuff are thin and steel as far as I know
1st Nov, 2013 at 07:08:12pm
i dont see why your not running moped disks and superbike calipers your mini weighs less than a harley Drives
1st Nov, 2013 at 07:09:35pm
Cos moped discs and superbike callipers dont fit - thats why Im thinking of making my own I seriously doubt it! |
1st Nov, 2013 at 08:47:51pm
together or on a mini hub?
1st Nov, 2013 at 09:24:48pm
Its the bolt PCD and ID of existing disks that cause the problem with using them on a Mini I seriously doubt it! |
1st Nov, 2013 at 10:10:09pm
could you not machine the disk in the middle and use a disk bell? then mount the caliper where required? Drives
1st Nov, 2013 at 11:01:42pm
Why bother? Might aswell just make one, I have to make a bell anyway I seriously doubt it! |
