| Home > Help Needed / General Tech Chat > Need help lowering my mini | |||||||
28 Posts Member #: 10398 Member Swansea , Wales |
4th Nov, 2013 at 11:15:07pm
Hi I've tried to look for a topic but was unable to find one so I made a new one , anyway I want to lower my mini to near the height of the mini in the link . I've currently got a standard set up I'm running shocks on the front and coil overs on the back and a rear beam. Not sure if I should buy hi-lows or cut the front trumpets and move the shock mounts height on the front , or cut the coil over mounts and rise them on the rear . My only concern if the wheels rubbing on the front when turning and rear inside arch , a long request but any help would be great , thanks jake
Edited by Jakej08 on 5th Nov, 2013. |
5th Nov, 2013 at 06:23:30am
I weigh about 110kg so if I came and sit in the back will that be low enough ? |
5th Nov, 2013 at 07:26:26am
You will get it low enough with either coilovers or hi lows on the front just make sure you get the lowered shocks.
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
5th Nov, 2013 at 07:33:31am
As per cossiericks comment, you'll need to tub your rear arches to sit that low. Also the the arches wrap over the wheels which makes it look even lower Edited by lee.pb on 5th Nov, 2013. What the mind can conceive the mini can achieve
5th Nov, 2013 at 09:26:54am
I'd echo the above comments; the arches, skirts and lip will also give added impression of it being low.
5th Nov, 2013 at 10:11:51am
I think those are the best the McLean arches ever looked, they wrap over too much now and look shit. On 26th Jan, 2012 Tom Fenton said:
5th Nov, 2013 at 08:09:06pm
lower it a bit and use Mexico arches give the low look.
