| Home > Help Needed / General Tech Chat > OT Knocking a wall down | |||||||
5th Nov, 2013 at 07:40:34am
In the 13's at last!.. Just |
336 Posts Member #: 9941 Senior Member Derby |
5th Nov, 2013 at 07:52:36am
Get into the roof space somehow and have a gander?
5th Nov, 2013 at 08:19:35am
how new is the extension, how wide is it, show us a photo.
5th Nov, 2013 at 08:25:21am
Do the roof joists run parallel to the wall or at 90 degrees to it? On 11th Feb, 2015 robert said:
5th Nov, 2013 at 09:38:01am
It's a pitched roof.
5th Nov, 2013 at 11:06:11am
If the joists are parallel to the wall you want to take down, the wall is not supporting the joists. On 11th Feb, 2015 robert said:
5th Nov, 2013 at 11:19:12am
From it's age and guesssing at size (as it has internal walls) it will most likely have required Planning Permission and probably Building Regulations approval (it's only recently a lot of rules have been relaxed).
5th Nov, 2013 at 01:19:48pm
If you are at all!!!! Unsure Get someone in to double check in or it will in catastrophe
