| Home > General Chat > Knock Sensor Group Buy | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
6th Nov, 2013 at 09:17:03am
I'm thinking about buying one of these
Class C 3rd Place Avon 2011 14.18 @101mph |
7th Nov, 2013 at 07:23:24pm
£354 Edited by Sprocket on 7th Nov, 2013. On 26th Oct, 2004 TurboDave16v said:
7th Nov, 2013 at 07:47:11pm
Colin can the vems do all that on a 6cyl?
Edited by Brett on 7th Nov, 2013. Yes i moved to the darkside |
7th Nov, 2013 at 08:34:50pm
On 7th Nov, 2013 Brett said:
Colin can the vems do all that on a 6cyl? meh, typed that without thinking, off to search anything up to 16 cylinders!! On 26th Oct, 2004 TurboDave16v said:
7th Nov, 2013 at 09:34:50pm
It is a lot.
In the 13's at last!.. Just |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
8th Nov, 2013 at 09:26:39am
I didn't think knock sensors worked with an A-Series due to all the random noise generated by the valvetrain. Metric is for people who can't do fractions. |
8th Nov, 2013 at 10:02:52am
Worked well on mine very well tbh
8th Nov, 2013 at 10:09:09am
Think I may have said this before ...placement of the sensor plays a big part I had it on the alternator bracket and got nothing but noise then the dizzy drive bolt and got very little compared to the det cans but when I put it on one of the top steady mount bolts it just worked Yes i moved to the darkside |
8th Nov, 2013 at 10:18:39am
Yes and no really,
On 8th Nov, 2013 Alex said:
I didn't think knock sensors worked with an A-Series due to all the random noise generated by the valvetrain. On 28th Aug, 2011 Kean said:
8th Nov, 2013 at 04:31:42pm
Wiring harness on the vems is extortionate
On 7th Nov, 2013 Sprocket said:
£354 at that price I think i'd buy anoter VEMS unit that comes with full sequencial injection/ ignition, EGT, closed loop boost control, and dual wideband in one box for £450! Who says you need to use it for injection ![]() Crystal Sound Audio said:
8th Nov, 2013 at 07:09:21pm
On 8th Nov, 2013 wolfie said:
Wiring harness on the vems is extortionate On 7th Nov, 2013 Sprocket said: £354 at that price I think i'd buy anoter VEMS unit that comes with full sequencial injection/ ignition, EGT, closed loop boost control, and dual wideband in one box for £450! Who says you need to use it for injection ![]() Lets put this into perspective Vems £164 https://shop.vems.hu/catalog/v3twinshieldha...d4b9dd0b284ba31 Emerald £222 http://www.emeraldm3d.com/full-looms-and-o...er-engines.html On 26th Oct, 2004 TurboDave16v said:
![]() 6752 Posts Member #: 828 Post Whore uranus |
8th Nov, 2013 at 09:15:44pm
yup joe is correct I run the xs knock lite ,works very well . if I hold it at 6500 on 6psi for about 3 mins it will just flash a little as the chamber heats up .
10th Nov, 2013 at 10:08:41am
How much are the Nocklite gauges? Looks like a better solution, as it takes engine speed into account. Where have you got your sensor mounted robert? Class C 3rd Place Avon 2011 14.18 @101mph |
10th Nov, 2013 at 04:13:32pm
matt mine is in the front bolt of the cyl head steady bar next to no 4.
10th Nov, 2013 at 06:22:08pm
I've had a look, but the xs knock lite gauges seem to have been discontinued on all the websites I find. Class C 3rd Place Avon 2011 14.18 @101mph |
11th Nov, 2013 at 12:45:10am
Looks like its eol. This looks close?
Edited by gr4h4m on 11th Nov, 2013. I run a supercharger and I don't care the TB is on the wrong side.
11th Nov, 2013 at 07:48:20am
Robert any pics of it mounted? I have the dsn alloy steady and wondered if it would still be ok to mount the sensor ontop of that or if the alloy would change the sound? Might be being stupid here...
11th Nov, 2013 at 08:55:52am
hi graham ,
11th Nov, 2013 at 09:39:26am
Thanks Robert.
11th Nov, 2013 at 02:02:10pm
http://www.ebay.co.uk/itm/Gizzmo-K-Lite-Kn...=item4acb95b7e9
11th Nov, 2013 at 07:27:47pm
Robert any advantage to getting a new sensor? I was just thinking that if I was going to spend the dosh might as well get a new sensor?
11th Nov, 2013 at 09:10:52pm
no idea graham ,but since they work for so long on production cars I felt one would have to have really bad luck to find a duffer ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Nov, 2013 at 09:15:14pm
Sensors are £10new with plug I personaly would buy that Yes i moved to the darkside |
11th Nov, 2013 at 09:22:12pm
http://item.mobileweb.ebay.co.uk/viewitem?...nid=69970355502
11th Nov, 2013 at 10:47:42pm
Ok dudes....
