Home > General Chat > hi lo help
afrance2905
Member #: 10512
whitby, north yorkshire
has anyone got minispares red dot cones and hi los, how much needs to be taken off the front and rear hi los to get the suspension sitting low?
cheers
I not sure I understand the question , if you have hi lo's then you just screw in or out to desired hight !!
afrance2905
Member #: 10512
heard they needed to be machined down to get it to sit right
You shouldnt need to machine anything, thats the idea of having adjustable hi los
afrance2905
Member #: 10512
ok was reading a old mini mag and saw someone had done it because they were maxed out on adjustment
miniminor63
Member #: 672
The oversills police
Oslo, Norway
The cones are taller, so the car might be a bit on the high side even with them on the lowest setting! I do not remember the amount though, sorry.
On mine it was just okay on the lowest setting when the cones had settled.
afrance2905
Member #: 10512
cheers al just take some off if i need to corner weight it
If i were you, set it normal mini height and then drive it for a while to let the cones and everything settle in, then set the ride height after a few days once you know it's all settled in. Else you might find the arch sitting on the tyre one day if you set it immediately.
afrance2905
Member #: 10512
yeah will be doing that till it settles
Also, are they budget hilos or genuine? My genuine ones should be able to sit really low,more than I'd ever need tbh, so it might be the budget ones that bottom out, but that's not a problem for most I don't think.
miniminor63
Member #: 672
Oslo, Norway
I have both the old ripspeed ones (the real originals) and the proper minispares ones. Both have been made shorter, but only when used with red/yellow spot cones
Edited by miniminor63 on 17th Nov, 2013.
afrance2905
Member #: 10512
cheers can get them machined at work al just keep going down until its right
alaskanow0
Member #: 8466
Mansfield
I just removed the locking nut and cut the thread down to get the car low enough.
Not to get it to sit right but to get it to sit low yes, fronts only I ended up with about an inch off the hi/lo but my car was / is extreemly low
Edited by Brett on 17th Nov, 2013.
afrance2905
Member #: 10512
thanks alot brett
supermotolee
Member #: 2153
kings langley
Did you cut that with an angle grinder?
On 17th Nov, 2013 Brett said:
Those are not Hi Lo's. They are High Lows *wink* *tongue* *happy*
no no no, these are low lows *happy*
and yes precision cut with an angle grinder. i believe they ended up shorter than that pic shows too
dazibee
Member #: 1356
TRURO, CORNWALL
Thats exactly what i did. With the red dot cones there was not enough adjustment in the hi lo to get a sensible ride height
Edited by dazibee on 17th Nov, 2013.
